Which is the best app to increase phone volume?
gumbo
Nov 11, 2007
i've noticed there are a few apps which claim to increase phone volume, can anyone recommend one that works well?
br3tty
Aug 20, 2008
And if I may add onto the question, is this safe?
Sounds a bit dangerous to be able to increase the volume?!?
gumbo
Nov 11, 2007
it just seems a bit quiet, i've missed a few calls as i didn't hear the phone ring
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
The audio amplifiers on Cydia/Installer never seemed to work for me.
I've found the best way to make ring tones louder is to use a free audio program like Audacity to amplify the volume and them import the ringtone to iTunes yourself.
I think there's another program out there called iRinger that will amplify the volume and import the ringtone for you.
Hope that helps.
