who knew the sleep button could cause so many problems...
imse
Feb 10, 2008
so my phone was in my lap when i was driving and it slid in between the seat and center console when i turned. when i fished it out, i realized that it was restarting. after i examined it, i noticed the sleep button is stuck down. so my phone just keeps restarting itself.
i took it to Apple and they said that they cant do anything at all but sell me a replacement. i have no idea what i should do! any ideas?
thanks.
psylichon
Oct 31, 2007
16,591
751
40
Philly
Take a small piece of rubber... a piece of eraser for example... small... and try to press the button down and shift it around a bit with the friction. Hopefully you can pop it back out.
Shame that the bahstids couldn't have just done it there easily with proper tools under warranty but I know that's not how Apple service is done.
imse
Feb 10, 2008
its not like stuck down, its jammed. ive tried wiggling it out, ive tried tweezers. im just going to keep playing with it, i might try taking to another Apple store tomorrow.
Hondamaker
May 14, 2007
9,946
671
56
Fairborn, Ohio
I'd go another Apple store, and if they won't at least try to fix it, speak to the manager. Seems like that is something they should at least try to work on. Good luck!
Nov 24, 2007
319
thanks.
thats BS.. some service.. if u know someone that repairs them get them to take a look at it
iamtko
Sep 18, 2007
2,004
23
Houston
yeah i would do like they said and try another Apple store. if they don't accept it, it's time to try and fix it yourself.
maybe if you take it apart then you might be able to fix it.
if you post a pic i might be able to help further
it's a worth a shot trying to fix it yourself and saving the money
powersrus
Jun 21, 2007
326
Battle Creek, MI.
Man I would sure try and take it to another Apple store. That is bs someone should TRY and do something for you. They should just exchange if for you even if not with a new one atleast a refrub! Dang good luck man!:mad:
