Why can't I copy and paste pics from computer to my iPhone 4s?
hijack2011
Sep 29, 2011
I just want to load pics from my friends computer to my iPhone. I want to load some pics from mine onto it also.
I try to copy and paste them from the file on the computer by right clicking and using "copy" and them right clicking and "paste" onto my iPhone files but it doesn't work.
If I can't just do this without downloading a bunch of crap I am selling this thing... On my old Samgung phone I can just copy and past both ways to transfer pics between any computer i want right to my phone...
How can I do this instantly. I don't have time to screw around, I transfer pics aot between my phone and many other desktop pc's and laptops...
Thanks...
RoofMonkey
Jun 21, 2010
8,913
1,979
Guess you might wanna sell that
Thing then :(
Or just email them back and forth, even a Dropbox account would
Work.
Sent from my iPhone4s using iCafe app
ITS ME DAVID
Jul 8, 2010
1,358
110
L.A C.A
isn't there an option in iTunes to manually edit music and pictures so you can sync between two computers and not lose any data
MuddyPaws
Oct 3, 2009
986
31
Even if...that would require iTunes on the other computer you are trying to get pics from and then changing the settings on that computer.
Not everyone uses iTunes. And if you are just trying to get some pictures out of a directory of a computer, it's a hassel.
I use PhotoSync at home on all my iDevices and computers and it works great but if you are somewhere else then that computer needs that program.
To overcome that, I have a thumb drive with the windows and mac version of it. It's a small, fast install of the program.
jaydoc1
Sep 23, 2007
608
I discovered the Air Sharing app in another thread. How I've had iDevices this long and just now found it I'll never now but using it you can drag and drop from your computer to your iPhone. Closest you'll get to doing what you're wanting to do without jailbreaking.
Proplayer44
Sep 13, 2010
75
Install the app box.net and get 50 gigs of free storage for life. Place all your Pics in the cloud from your PC then grab them from the cloud using your box app.
Lon
Jun 5, 2010
2,946
132
Alaska
Check out some of the limitations in the used of the Box App. It may not be that suitable for media files.
psylichon
Oct 31, 2007
16,591
751
42
Philly
I second this. The Air Sharing app is awesome. The only downside is your phone and computer need to be on the same wifi network.
