Why doesn't iMessage work on 3G anymore?
Luis.g.95
Feb 3, 2012
Ever since a couple of days ago, I can't use iMessage on 3G. It just sends messages as texts. It works perfectly fine on wifi.I have an iPhone 4S running on the latest update if that helps. Is anyone else experiencing this problem? Or know how to fix it?
OhMatty
Feb 22, 2012
11
NorthEast Texas
I have a 4s (CDMA) running on 5.0.1 firmware. I just tested iMessage on 3g and it seems to be working fine for me.
Here is a little something I came up with in a quick Google Search. -->
"Enorym writes...
don't worry.. I just found out you can only use iMessage over WiFi.. which I think is total BS..
Not true at all i have been using imessage since ios 5 beta 1 and it works over 3G
It would only work over wifi on the ipod touch and non 3g ipads as thats the only source for data..
Also if there is no data connection it will default to sending an sms"
The site that came from can be found... HERE!
EDIT-- Also, it may not be your phone that isn't working with iMessage. The recipient on the other end of the text may not have their iMessage on. I've had that issue with iMessage texting (well iMessaging >.<) my girlfriend. She never has her's turned on so all my messages are sent as texts.
JDem
Jan 19, 2011
265
27
NNJ and Central PA
Actually may have been a spotty, minor iMessage "outage" over the last couple of days. I've had a few people (all iPhone users who I normally can iMessage with) tell me they've texted me and either got no response (because I did not receive the message) or that I was green (regular SMS) when they sent a message.
Oddly, the only people I've been having iMessage issues with are other VZW customers. Seems to be working as normal today.
Luis.g.95
Feb 3, 2012
Thanks for the input :) I found out how to do it, all I did was reset my network settings and write the information back on :)
