why dose my speaker make that noise...
Avonalliv
Jan 15, 2008
11
it is interference coming from the GSM radio in the phone. i read somewhere that GSM causes more interference than CDMA, too.
only way to stop it is turn it off.
Actually, you can prevent it by turning on Airplane Mode in the Settings menu. Airplane mode prevents incoming and outgoing signals.
Turning off the phone will prevent syncing.
- John
Apple needs another update to fix this radio signal shannigans.
That's not the fault of either Apple, the iPhone, or AT&T - it just happens with phones. Most computers and docking stations are now made to prevent that noise from being made; mine for instance, does not emit it. The OP most likely has on old machine.
- John
