Why is it so hard to change damn firmware.
AmPed
Apr 13, 2008
It took me 2 hours just to put my phone to 1.1.3, but now I want it to go to 1.1.2 so i can use customize...
And i get "an unknown error occurred (1)" ive used all this ibrickr garbage, but no luck.
darklight
Mar 23, 2008
123
Boston.
i have 1.1.3, customize works for me.
use Customize 2.0.
works beautifully.
AmPed
Apr 13, 2008
I gave up on jailbreak, its a pain in the ass, that i honestly cant keep up with.
And after putting it back to 1.1.4 with no JB and apps, my battery lasts so much longer.. I did like it, but my phone was going dead midway into the day..
thanks for all your guys' help, maybe ill try it later :)
THEHNIC
Feb 11, 2008
97
CA
May be me but if you don't like JB your iPhone how would you use customize.
Jeremiah
Jul 11, 2007
41
Maryland
Uh, you can get customize working with 1.1.4.
Download the customize from googlecode or something. Then extract. You need like winrar or something for the tar.gz. You also need winscp and putty. Basically you put customize on manually, and then run 3 commands from putty.
Just google how to put customize on 1.1.4. I believe there are even easier ways to do it. But i did mine in about 10 mins.
So basically, upgrade to 1.1.4. ziPhone jailbrake. then follow those ^^.
