Why is Pwnage closing and not letting me jailbreak?
isal
Mar 22, 2009
136
Toronto
I have a 1st gen iPhone and I updated to 3.0 but now I can't jailbreak the phone.. I keeps crashing..Can someone help me please...:mad:
Did you update using iTunes? or the Pawnage tool?
If you did it through iTunes then you'll need to go back to 2.2.1 using the Pawnage tool.
Step 1: Get the 2.2.1 Firmware, just Google it, you'll find it easily. Go to the Pawnage tool and create a custom firmware. Put your iPhone in restore mode and on iTunes press "Option + Restore" and the select the custom firmware you created.
Step 2: After that repeat these steps with the 3.0 firmware.
If you did it through the Pawnage tool just do Step 2!
hotskate
Sep 21, 2007
314
34
i used that tool and now have the phone up and good but don't have a tmobile sim to check :( the wifi isn't working is (i have the bars though with it connected to my router)
