Why wont some photos show on iPhone?
loopi_lu
Nov 6, 2007
hey guys,
I try to upload photos, but it says some photos wernt loaded because they cant show on the iPhone. what do i have to do to change it?
Griffinaz
Oct 5, 2007
1,046
Phoenix, Arizona
hey guys,
It appears that there are some known issues with (depending upon where you research it) either, SATA drives, Windows Vista, or Windows Xp running on an NTFS drive. The below site talks about the NTFS problem. The work around is to copy the images to a flashdrive or non NTFS or SATA drive and sync them from there.
http://i.nconspicuo.us/2007/10/28/s...ws-vista-using-itunes-sync-pictures-solution/
geordisjd
2,442
hey guys,
What format are they in? Not all image formats are supported by iPhone. If so, use a graphic program to switch to a common file format like .jpg and they should import.
