Wi-Fi Calling Now Available for AT&T Users
Rafagon
Dec 7, 2011
7,567
1,254
45
Miami, Florida
Rafagon
Dec 7, 2011
7,567
1,254
45
Miami, Florida
After you turn on Wi-Fi calling, phone calls via Wi-Fi, as well as SMS texting, work when on Airplane Mode if Wi-Fi is on. Here's a screenshot from my phone:
I see no reason not to use it this way all day long, provided I'm going to be in a Wi-Fi area. It would probably yield slightly better battery life if I have the cellular radio turned off. YMMV.
iPutz
Nov 20, 2012
964
186
43
72
US Midwest
I just found out that WI-Fi calling is live for AT&T in the Chicago-land area. Went to Settings/Phone and the Wi-Fi calling toggle is active. The only caveat is that 911 call responders may be sent to a preset address. Your home address is the default but it is changeable. Time to do some reading and then go play.
47seijar
Oct 6, 2012
342
126
43
Denville, NJ
How long before Verizon finally enables WiFi calling? They're the last tier one carrier in the U.S. that doesn't have it.
Nov 8, 2014
50
I turned Wifi Calling on and tested the airplane mode as mentioned and did not get the same.
I turned the feature on a few hours ago and went through the entire setup. Is it possible it's still not available for me or my area?
5,578
T-Mobile has had it for a long time. I've had it on my T-Mobile phone for well over a year. I just tried to enable it on my AT&T and it finally appears that it's going to work. It said it would be available in a few minutes, but that was over an hour ago and it still hasn't activated. Hopefully, I can test it out tonight. I'm excited to test it because I'm hopeful that audio quality will be better. For some reason, FaceTime audio quality degraded a week or so ago and has been so bad it's been unusable since.
5,578
Sounds like it's still pending. Give it some time. You'll see "AT&T WiFi" in the status bar when it's activated. You'll see "AT&T" if not. Both will show the WiFi symbol as it's always appeared. You don't have to go into airplane mode to see this.
Nov 8, 2014
50
I did some adjusting and it now says "AT&T Wi-Fi" in the status bar.
5,578
I haven't heard an exact date yet. We didn't have one for AT&T. They started rolling it out a few months ago on AT&T, but it was limited to cenrtain cities. Some of the people on the iOS 9 beta had it last summer.
5,578
What did you adjust? Mine hasn't activated yet. I toggled it off and then back on and rebooted. I put in the 911 address earlier today.
Nov 8, 2014
50
Up until that previous post I assumed that everything was normal.
I put the phone in airplane mode, and then turned WiFi back on, waited for a few seconds and the new status appeared. I then turned airplane mode off and the AT&T WiFi status has stayed in the bar.
5,578
I reset my network settings and went into airplane mode, turned WiFi on and then toggled airplane mode back off. Still not activated. I'll just give it some more time.
raqball
Jan 30, 2011
1,079
199
So. California
I don't think you will get a notification saying it's activated... I didn't but it's working for me. If you want to test it to see if it's working just turn on Airplane Mode and make sure WiFi is connected. If you are up and rockin' you'll see AT&T WiFi next to the Airplane Mode Icon
5,578
I'm not waiting for a notification. I'm just waiting for it to show up in the status bar. It's toggled on, but it still just says "AT&T." I've gone into airplane mode and reset network settings, but it's still not working/activated.
raqball
Jan 30, 2011
1,079
199
So. California
Weird.. Mine was up about 10 seconds after I turned it on.. Maybe it's delayed for some locations?
5,578
It said it would be available "in a few minutes," but that was a couple hours ago. I'm sure they are just bogged down.
Rafagon
Dec 7, 2011
7,567
1,254
45
Miami, Florida
They will first try to locate your iPhone using GPS. If that doesn't work, then they'll fall back to the preset address. This is from the AT&T website:
If you're able to speak at the time you place the call to 911, I'm assuming you can always give your location verbally and that should override anything else.
Mrbjr
Sep 19, 2015
11
Took about 5 minutes total, I'm in central CA if that makes any difference.
5,578
Still not working here. AT&T said they have been having a lot of trouble with it. I called them before my last resort (restoring) to see if they could work any magic, but they show it as active for my phone and just had me do the same troubleshooting I had already done. Restoring to factory settings now.
5,578
Still not working here after a restore to factory settings. It lets me toggle it on (it never let me toggle it on before today), but it still just says "AT&T" in the status bar. AT&T just said to take it into an AT&T Store, although they probably won't have any information that he doesn't have.
