Wi-Fi not working
gcvt
Jun 21, 2007
1,029
San Francisco
When I'm at home using my Airport Express, my wifi works flawlessly.
However, when I'm at my girlfriend's house, it doesn't work at all. She's using a Belkin router and it works fine with her MacBook and my MacBook Pro.
My iPhone says it's connected to her network, gives a full signal on the wifi icon, etc. but when I try to load a webpage, it tries and tries and then says "Safari can't open the page because it can't find the server.".
Very frustrated! Any ideas?
I can post the details from the wifi menu in Settings if needed.
Fred87nc
Jun 19, 2007
276
theres a wifi connection aroun my gf house and same thing gets full signal but edge is still active i guess Apple doesn't like belkin anyone find a solution also what cheap router do u recommend cause i need one for my house for my clearwire (clearwire sucks btw)
charlich
Jun 18, 2007
Wifi solutions
I had similar problems but spend 3 hours of quality time with Apple tech support last Sunday solving my problem. First, reset your router by unplugging it for several minutes. Then reboot your router. Reset your network settings on the iPhone. You probably need to reset your iPhone wifi setting to Wep +Hex not Wep. Then you should be prompted for any encryption number if you have it. It's as simple as that but I had the good folks at Apple scratching their heads. You may need to repeat this process if you move from one hotspot or wireless setting to another. Oh well....
Despite the length of time , the Apple people were great! Best.
sparkle
Jul 5, 2007
tried firmware update?
I had similar issues with a dlink router but I just upgraded the firmware and it worked like a charm. My wireless router was about 2.5 years old. It's worth looking for new firmware if you're having problems.
rollinfromhell
Aug 1, 2007
1,232
44
Ok, when I use my neighbors across the street its fine! but when I try to use my own network, i have a D-Link DI-514, and itll work on the first few websites, then go extremely slow to almost nothing, and i can be at low recepetion and itll be just as fast in the first few websites.. anything I can do? I've reset the router, changed it to WEP and still wouldn't work...and yes wireless on the laptops work good, but the iPhone..
Crash Override
Aug 9, 2007
178
Have you updated your firmware?
I had issues with all my gaming devices connecting to my home wifi. (XBox 360, PS3, Wii) until I updated the firmware on the wireless router. The 360 was slow and the other two wouldn't connect at all until I did the firmware update. Now they all connect easily and run fast. This was before i got my iPhone, but I've had no issues getting wifi at home with my iPhone.:)
jaybird360
Aug 23, 2007
Got it!
My boyfriend figured it out...just need to Login to Belkin web site and allow the iPhone to access...I guess I had some security set up that wouldn't allow the iPhone to access the router. Now all is well. I can get more detailed instruction if anyone needs it. I'm not too techy but I'm sure my boyf can type out the details if I ask, post here if you want them.
:laugh2:
joaoeduardo87
Oct 2, 2007
Could u please tell me how u fixed this problem thanks.
:laugh2:
sedated_xtc
Feb 19, 2009
Has anybody had this problem where you connect to a wi-fi network, your upside-down 3-tier wifi cone pops up beide your reception bars but when you go to any page on Safari, it says that "Sarfari cannot connect to the requested page because it's not connected to the internet"?
HELP MAKE THIS GO AWAY! =(
sim
Aug 19, 2008
58
Rochester, MN
Make sure your internet connection is live/working.
I have had two instances lately at home where my Charter cable internet was out. The wifi cone shows because the network is there....just no internet connection.
Steve
dturner
Dec 15, 2007
5,725
Louisville, Ky.
Steve
(red faced) Yeah, that might be a better first place to start.:eek:
PDACPA
Jan 16, 2008
542
My iPhone one day came up on the settings page with the grayed out words "no wifi" and obviously no signal.
The solution was a replacement iPhone from Apple.
celebrian
Feb 11, 2009
Wifi not working
I've had this problem over the last two days, wifi works on laptop and desktop computer, network shows up on iPhone but "Safari is not connected to the internet". I've just Restored my iPhone and re-synced it, and everything works again, so you could try that; make sure you back up your settings first.
iNinja
Aug 8, 2008
3,986
20
UK
I had this problem when the router i was trying to connect to is using WEP encryption. If yours is, change it to WEP 2 and give that a go
