Wi-Fi Password
Cooley470
Dec 22, 2007
Hey, I can't connect to Safari or youtube because I have a string of code as my wi-fi source, and it needs a password, can somone help me find where I look for the password?
Cooley470
Dec 22, 2007
Ok so I went in settings, and it says I have to find my Dns, search domains, and client id? What are these, please help.
meiphones_brill
Nov 16, 2007
797
if you don't know what they are, then you certainly won't know what values to put in there. If this is the setting on the iPhone you're referring to - you will almost certainly not need to enter anything - you will have the DHCP option selected probably and all these settings will be transmitted to the phone from the router when you connect.
The password will be specified in your router settings. You should have a manual somewhere.
Cooley470
Dec 22, 2007
i have an iPod touch, but thank you, ill look in the manual, im not thinking. im just excited
KNK
Jul 22, 2007
2,391
Stevenson Ranch
You need to use the same router settings that you used to set it up.
In the iPhone set the wifi to on and select to discover any wifi. Then your phone will ask you to join and then enter your passPhrase.
