Wi-Fi won't show up....
dankduke
Sep 11, 2007
278
Austin, FL
So wi fi will not show up on my iPhone 3g
i have the latest firmware on there and i have a belkin wifi router and it is password protected
i enter the pw into the iPhone and it connects but no wifi shows up or works...
what gives?
(phone was jailbroken at one time, but then i updated with new firmware)
it is essentially clean rite now...
how cna i fix this? please.thanks
GSA190
Oct 29, 2007
401
New York
I had this same problem various time. I just turned off my router and kept it off for a good 30 second then turned it back on. My phone picked up the signal right away after that.
dsplinter
Sep 27, 2007
Wi-Fi Issue
There seems to be quite a few people (+/- 1500) experiencing this same issue over at Apple's forum. I think 2.2.1 breaks Wi-Fi.
dankduke
Sep 11, 2007
278
Austin, FL
resetting doesn't work anyhting else or a resolution?
damn this is crazy
EGAR
Jan 27, 2009
20
Texas
my wi-fi works fine on 2.2.1 so i'm not sure whats happening with the op's iPhone
hurlthis22
Jan 12, 2009
62
31
Moorpark, CA
go into your wifi settings. delete it off of the list. restart the phone and make it connect back to it as a new network. it will ask for the password. this has happened to me and works everytime.
shutter13
Jan 8, 2009
2,208
153
Does this occur on all wifi networks or just your home network? Do you use mac filtering on your home network? If so have you entered your iPhones mac address into your router?
