Wife's iPhone 5 not charging
No clue
Oct 6, 2013
It wont charge with any chrger we connect it to. Just started after loading ios7. My old 4 did same thing. Message says "charger is not a certified charger". It came with the phone.
Sent using iCafe app
RoofMonkey
Jun 21, 2010
8,891
2,057
It won't charge with any chrger we connect it to. Just started after loading ios7. My old 4 did same thing. Message says "charger is not a certified charger". It came with the phone.
Try blowing out the bottom of the phone with a little compressed air. Might be a little bit of lint or 'gunk' on the contacts.
No clue
Oct 6, 2013
Will do. Thx
5,578
Sometimes the inside of the port has to be scrapped with an exacto knife. If blowing out the port with compressed air doesn't work, try a new cable. If neither of those work, take it to Apple so they can professionally clean/scrape out the port.
iPutz
Nov 20, 2012
962
184
43
72
US Midwest
I'm assuming you have already tried a different charger and cord, a re-boot and a hard reset of the phone plus Europa's suggestions. If you were unable to charge the phone from the moment you installed iOS7 then it seems awfuly coincidental for the problem to be with the connector or cord. You could try restoring the phone from a back-up and if that doesn't help then restore as new from iTunes. If all the above doesn't cure the problem it may be time to consult Apple.
Sent using iPhone 5
dalina
Oct 22, 2013
Have you reset it all, this happened to me too in my 4s.
Restore it to default settings and it will work, at least it worked for me.
Oct 26, 2013
14
Take it into Apple. If it is within the 1 year warranty period they will give I a brand new one right over the counter. If u want to save all your setting on there back up to iCloud first. If too much to save and 5gig free icloud space is not enough. Purchase more space. Less headache and u don't have to renew.
Good luck. I'm on my 2nd replacement!
