WiFi Connection on iPad Air
pserena
Aug 31, 2010
Can anyone tell my why my Ipad Air will not connect to my home WiFi? It has connected before and I have other devices on my router and my Ipad connects ok to other WiFi locations like a public areas. I've reset the router, cleared all internet connections on my Ipad and it will not connect. Any suggestions...
Dec 15, 2008
5,386
340
Pensacola, FL
Have you tried rebooting the iPad Air and connecting it to your computer to see if it'll then connect? I am reading now to try to remove the case or covering if there is one and then connect it. It says this could cause the signal to lose some strength.
I am also reading now to turn airplane mode on, go to settings-general-reset, press reset network settings, confirm the reset. Then turn airplane mode off.
As you can tell there are a ton of tests and or fixes for this online.
Dec 30, 2015
Yep, same issue here. Got my new iPad Air 2 yesterday, got it setup, but the wireless connection drops and does not stay connected. Every time I start use the iPad, the connection is not there. Reboot, does not make a difference. Turning on and off the wireless helps, and eventually get a connection. No issues with my iPhone, new Macbook, or other devices. Just the new iPad Air 2. Have the 64gb version.
5,580
Have you tried resetting the network settings on your iPad?
