WiFi help needed urgent pls :(
damion
Jun 5, 2008
hey guys i need help pls, i think my wifi is confusin with edge, i was on 1.1.4 wifi works perfect eversince i upgrade to 2.1 my wifi stop workin, then i upgrade to 2.2 still works on and off i don't knw wats goin onn,, i did everything there is and ntn don't work is there any one with the same prob, am having this prob from october lastyr......... i need my wifi to b workin fine guys i do appreciate all the help i can get plsssssssssss:( :(:(
iNinja
Aug 8, 2008
3,985
20
UK
Hi, i had the same problem, and apparently since the 2.x update the WIFI security is a little tempramentle. I had to change my router security key at home from WEP to WEP2 or another setting.
I think this should help. Let me know
