WiFi Jitters
sid1881
May 6, 2009
Recently I happened to at an airport which had free wifi service. I tried to connect my iPhone to it and was able to do it successfuly. However I was not able to surf the web using it. Edge is also enabled on the phone. Can someone tell me what can be the issue?
iNinja
Aug 8, 2008
3,984
20
UK
Yup, sometimes even though a Wifi zone doesn't have the lock symbol it doesn't mean its not protected. In the UK airports, BT have Wifi, that isn't protected, but when you try and use it, unless you have an iPhone contract or are subscribed it simply wont load... try another wifi spot. I would bet that its the Wifi zone's problem not yours!
