WiFi not turning back on after sleep?
M
Macrosee
Guest
So as well as my WiFi keep randomly dropping it also doesn't always come back on, especially after sleep, sometimes I can get it back by manually switching WiFi off and on again but sometimes I have to reboot the phone! Anyone else having any WiFi issues at all?
MrMike6by9
Nov 16, 2008
1,482
121
70
Maryland, USA
Which model of the iPhone do you have? What version of iOS are you running? How many wifi connections are in your home or close by that your phone can see?
I have an Extreme in addition to the home's verizon router ... that's 2 home networks. It's not uncommon for my 5S to pick up the Vz router before connecting to the Extreme when I return home. I've also seen this first thing in the morning but not recently. I've usually noticed this because my Extreme has the faster connections.
|3are
Jun 13, 2008
730
17
Texas
I am experiencing similar issues on my Plus. I'll be messing with it for a little while before noticing it isn't on wifi anymore, and when I go into the wifi settings, it shows the spinning icon next to my network like it's trying to connect but won't. Then if I switch wifi off and on, it'll connect again.
I'm chalking this up to a small bug and hoping that a fix is coming in iOS 8.0.2 (even though I heard 8.0.1 didn't address any wifi issues).
chris
Administrator
Administrator
Jun 10, 2006
11,813
1,779
Long Island, NY
My wife's iPhone 6 had a similar issue with WiFi. Toggling it on/off did not resolve the problem. I rebooted the phone and it worked.
MrMike6by9
Nov 16, 2008
1,482
121
70
Maryland, USA
We have been experiencing my phenomenon since before 8.0. I just figured it was merely our particular situation. I've seen the same thing, the spinning icon. I leave "ask to join" on. My preferred network shows up in the list 99% of the time so it's a simple tap to rejoin.
YMMV
M
Macrosee
Guest
iPhone 6, it is iOS 8, two connections.
MrMike6by9
Nov 16, 2008
1,482
121
70
Maryland, USA
I've reset per the instructions and restarted. My 5S connected to the preferred network. I'll report back after leaving the house for a while. Thanks
MrMike6by9
Nov 16, 2008
1,482
121
70
Maryland, USA
I returned home a while ago and my 5S reconnected to my preferred WiFi network upon arrival. The fix appears to have worked as suggested.
Many Thanks
Dec 15, 2008
5,386
340
Pensacola, FL
I had this happen to me too this afternoon. Wifi was on but it showed no wifi anywhere. Rebooting phone fixed it.
Jin
Oct 2, 2012
99
So are we suppose to reboot the phone every time. A bit annoying.
Sent from my iPhone using iCafe Forums
