WiFi out of the USA?
Jul 24, 2007
I am thinking about buying an iPhone but spend most of my time outside the states. I will most likely do a decent amount of travel in the states and that is why I want the iPhone.
My question is if I sign up for the service and dataplan etc, can I use the iPhone as a web browser, email client, PDA type device while not on the AT&T network?
cdodkin
Jul 2, 2007
305
SoCal
www.d30-images.com
Basically yes.
You can roam onto another foreign carriers cell networks, as long as they provide data connections, and get Email and the web. Roaming charges from AT&T will apply, so look at your AT&T plan, and ask them if you can pay for data roaming ahead of going abroad to get you a decent rate.
Also, you can use hotel and other free wi-fi hot spots to get Email and Web, without paying roaming charges - you simply use the free Internet hook-up via the wi-fi.
Note - visual voicemail will probably not work when you're off the AT&T network
Also - leaving you iPhone set to automatically download Email, while you are roaming abroad, could be very very expensive without the AT&T international data roaming plan in place - BE CAREFUL!
