WiFi question
cere1bro
Oct 27, 2007
Does anyone know if the iPhone shuts off the wifi when it goes in to standby?
shawn
Oct 11, 2007
77
I certainly think it would. Otherwise the battery consumption in standby would be relatively enormous. "Standby" pretty much halts all functions except for the clock, ipod, & phone-standby.
Ramesh
Jul 12, 2007
4,571
Irvine, Ca.
yes it does. I know this b/c if you try to OPENSSH into the phone when the phone goes into standby it won't connect.
cere1bro
Oct 27, 2007
That's good to hear, thanks for the quick replys guys.
OniKoroshi
Oct 25, 2007
41
Next time you are connected to wifi, put your iPhone in sleep, then wake it up. You'll see the E EDGE icon quickly change to the wifi symbol.
TJL7386
Nov 14, 2008
102
Michigan
Ok here is the info:
3G iPhone
3.1 OS
No JB
U-Verse Home Wifi
My iPhone suddenly won't find or connect to my home internet connect. It has worked fine for more then a year and then all of a sudden it stops. I have two other computers at home and they find the connection just fine so I am assuming it has to be the iPhone. Has anyone had problems like this and what are some solutions that I can try?
28,365
5,506
Try resetting your network settings. It's likely due to the 3.1 update, apparently it has lots of bugs. If nothing works, you can revert to 3.0.1 or just wait for the 3.1.1 update.
MrMike6by9
Nov 16, 2008
1,482
120
70
Maryland, USA
3G iPhone
3.1 OS
No JB
U-Verse Home Wifi
My diagnosis would begin with these questions - Do you have a WiFi signal? Have you restarted the phone? Have you deleted the WiFi account, restarted the phone, then re-entered the Wifi account info?
I've also had problems since the 3.1 update. In my case, it seems to be mostly 3G signal bars going to 1 to 2 bars. If I restart, they come right back to 4 1/2 to 5 bars.
TJL7386
Nov 14, 2008
102
Michigan
I do not have a Wifi signal any more. I have tried restarting the iPhone and then manually entering the information but that didn't help either. I do pick up other wifi signals but for some reason mine has stopped working.
MrMike6by9
Nov 16, 2008
1,482
120
70
Maryland, USA
Is there a chance that your router is configured to only allow a limited number of connections and that your phone is now outside that limited number? People often configure the router this way to avoid unauthorized folks from piggy-backing on their service.
