WiFi restart.
derohanes
Apr 3, 2010
My 3GS will lose the wifi signal and when I go to reconnect it tells me that it cannot join the.network. I've tried to turnoff the wifi on settings and turn it back on, but that does not work. I have to go to my hub and unplug and plug to get the phone to find it. I drop connections at work also, but I can't unplug that. Is there a way to get this connection back in another way?
Torinate
Sep 19, 2009
325
Been there...
Reset network settings in the iPhone.
You will have to renter the wifi passwords again after, so copy them to notes beforehand if need to.
This worked for me.
Good luck.
derohanes
Apr 3, 2010
I have turned wifi off then on. Is that the reset you mean? I've done it in the wifi and network areas.
