WiFi signal strength unstable
Johnlennon78
Dec 25, 2011
43
Hello guys,
Have you noticed that on ios6 it takes much longer to load an app? For instance when opening icafe, it takes me at least 10sec before it loads the thread... Also I noticed that he signal meter for the wifi is unstable. I am standing next to my wireless router , and the meter shows me 2 bars than 3 than 2 etc... Wonder what causes that? Anyone Having the issues?
Torinate
Sep 19, 2009
325
Wifi unstable yes. Goes from 0 bars to full strength.
Thought it was just my wifi itself though. Think I'll reset it and see what happens.
Lots of lag when typing in this forum too. Not sure it's IOS 6 though.
Jim B
Feb 16, 2012
11
Nottingham, UK
Yes, I'm having to trouble with WiFi. I thought it was just my iPhone 4
I not having problems with connecting to a WiFi network, but it often drops the connection and I go onto my 3G coverage, then it picks the WiFi back up.
And also I don't seem to get the WiFi range I did with iOS 5
All in all I'm quite disappointed with iOS 6. I believe it was rushed before it was actually ready for release.
memnautikus
Nov 6, 2007
116
thomasville ga
I'm having same problem. I even restored. Still the same. Keep getting kicked off wifi. And I keep having to manually log in to already logged in wifi at home.
jmp316
Jul 10, 2008
1,048
141
Mine isn't the best on my 5 either. I'm hoping it can be fixed in a software update...
EverythingApple
Jul 28, 2010
3,867
223
North Jersey
And, I thought my problem was with my FiOS router so I rebooted it and it's still happening. Apple needs to get it together before releasing new iOS and new iPhones.
Torinate
Sep 19, 2009
325
Same here. Rebooted my router and still the same dropping wifi signal. Full bars and then none - just the dot. Then back again. Occasionally I drop back to 3 G.
Can't believe all the problems with IOS 6. Not Apple like at all.
Quite disappointing really.
Saw a cool commercial for the Galaxy S3. It sounded like its light years ahead still - even over the 5...
I don't know though... Got so much invested in apps...
jmp316
Jul 10, 2008
1,048
141
I reset network settings yesterday and things seem to work fine now. I still think mines a software issue so I'll wait until an update comes out.
efuseakay
Nov 11, 2008
864
99
Of course a Samsung commercial for one of their products is going to make it appealing. Trust me. Android and especially the S III aren't without their own problems. There's no such thing as a perfect phone.
I know it's no consolation, but my wifi has been rock solid on my 5. Even on 5Ghz N.
Torinate
Sep 19, 2009
325
I realize that no phone is without problems. I guess I didn't expect the sheer number of issues with Apple.
The Samsung appears to have several features that are still beyond the vaunted iPhone 5 though. I don't mind giving up these features for a phone that flat out works. However, when I encounter having several problems and a phone that is still behind the leaders in many ways, it's frustrating. It does force me to look at the options as it will with many.
Will I get the S3? Doubt it. But it has made me at least peruse the idea. If everything worked as it should (and did), I wouldn't have any inclination to even bring it up.
In my circle, there have been a few that have left Apple and many that are contemplating. I think the deciding factor will be Apple's response (or lack of one) to what IOS 6 has become.
Again, my opinion. Ymmv.
Jamagan7
Nov 2, 2011
I have the same wi-fi problems: (1)inconsistent connection; must re-connect through the day at hone. (2) the range is definitely less than in ios5.0.1
PDACPA
Jan 16, 2008
542
I typically now switch to LTE as the wifi is so slow. I have rebooted routers, etc. I will wait till the initial iPhone 5 orders get full filled and then make a genius appointment and get a replacement unit if a software update does not solve the wifi woes.
BillF
Mar 5, 2012
22
I'm having the same problem with my 4S and IOS6 dropping wi-if every once in a while while here on my home wi-fi network. It never did that before I upgraded to 6. I'll look at the phone and it will be saying 3G and then go back to wi-fi all by itself. I've also noticed that if I go to settings, general, usage, cellular usage it will show cellular network data has been used. If I reset the stats and check again after a while it shows usage even though its still connected to wi-fi. Is this normal? Should it show usage? I also see the wi-fi signal strength varying even though I have not moved the phone.
BillF
Mar 5, 2012
22
No, I am on Sprint, but thanks for the reply. I got my new 32 GB iPhone 5 a few days ago and it has not dropped my home wi-fi link even once. My wife is now using my 4S and as part of the process of converting it over to her my local Sprint store basically wiped it and started it fresh for her. I think that may have helped since she hasn't complained about it dropping off, but then she may not have even noticed although I did warm her to watch for the problem.
Prmatheron
Mar 28, 2012
Hi
I updated to iOS 6 on my 4s and had wifi issues and it took all my data same now on iPhone 5 so I am for sure it is a software problem an not the hardware. Hope they release update really annoying used all my allowance in 3 days.
