WiFi store on my phone - in GERMAN?
trant01
Jul 14, 2007
27
can someone tell me why the wifi store on my phone is in german? Thats great and all except that I'm American and don't understand german. Thanks in advanced.
meiphones_brill
Nov 16, 2007
797
Was ist ein Wifi Store ?
You mean iTunes? Maybe your international settings are set to Germany? Does it do that?
meiphones_brill
Nov 16, 2007
797
Doby45
Aug 21, 2007
543
Powder Springs, GA
If you are on 1.1.2 you could try removing the German langauge directory for the iTunes store. After I upgraded to 1.1.2 I went back into my phone with WinSCP and deleted the German and French and some other langauge directories. I figured it would give me more install room, I don't use those langauges anyway and my phone has been fine.
Griffinaz
Oct 5, 2007
1,046
Phoenix, Arizona
But doing that when a piece of software is using it could hose the phone. If he removes the German langauge directory and then the WiFi store goes to look for it, he might have serious problems. I would get it fixed first then consider removing the files no longer needed.
