WiFi sync blocked by avg
Kahe
May 25, 2010
when my avg is on, my wifi sync is not working, only when turn off it works
rambo47
Apr 4, 2010
528
79
Northern NJ
AVG is doing exactly what it's supposed to do. It's protecting you from intrusions. Either make an exception or just turn it off when you want to sync.
Kahe
May 25, 2010
I already created an exception for iTunes. that was the first thing I did thinking about solving the problem,did not work. I call avg tech. but everybody in the village speak Chinese so my problem still exists
blastewitz
Feb 3, 2011
51
39
Bognor Regis
I already created an exception for iTunes. that was the first thing I did thinking about solving the problem,did not work. I call avg tech. but everybody in the village speak Chinese so my problem still exists[/quote
Try this path if you're on windows. I've had avg and had the same problem. i don't remember exactly if it's the right one but you should give it a try. i'll look into it later on if this doesn't help. reply pls regardless of the result.
blastewitz
Feb 3, 2011
51
39
Bognor Regis
try this one. you never know it might work. i hope it does because it was a pain for me until i got it figured
whiteghost
Jan 31, 2010
98
Manchester UK
Here are the AVG settings that works for me!
open up your AVG prog!
Go to TOOLS, advanced firewall settings
Under the firewall profile you use, go to system services "left hand pane"
Manage user system rules "Bar below right hand window click on it"
Click on the ADD button?
create two new rules and put in these settings :
first=
protocol = TCP
direction = Out
local port(s) = All ports
remote port(s) = all ports
remote address(es) = all networks
Allow for ALL
second=
protocol = UDP
direction = Both Ways
Allow for ALL
After you've done the above, restart.
Good luck :)
