WiFi troubles
RyanFavre
Mar 16, 2007
250
Milwaukee
So in the midst of drooling/loving my iPhone i've encountered a problem connecting to my wireless network at home. Its protected and i type in the correct password and its not connecting.
I don't expect any one to know how to solve this problem (if you do, i'll be extremely impressed), but i was wondering if anyone was having a simlar problem so if i know its the iPhone or its me.
DD0
Jun 21, 2007
183
Mine connected fine. Try reseting your airport and make sure the pass is right.
RyanFavre
Mar 16, 2007
250
Milwaukee
thanks for the help guys but still not working.
the edge isn't that bad though--i'm sure i'll get it connect eventually.
Twinnie
Jun 13, 2007
193
Try turning the security off on your router and see if that helps. You don't have to leave it that way but it might be that the router's using a security setting the iPhone doesn't support. You don't have a MAC address filter on do you?
theraker007
Jun 15, 2007
322
try turning the phone off and on, maybe it just got locked up
id also try unplugging your router for 30 seconds and then plugging it back in
RyanFavre
Mar 16, 2007
250
Milwaukee
thanks for your help again guys i figured it out. i had to change the password setting for wep password to wep hex password. yeah wifi now!
