Will I be able to downgrade iPhone 5 to iOS 6.1.2 and re-jailbreak?
dankduke
Sep 11, 2007
278
Austin, FL
so i was with my daughter and we got caught in a torrential downpour and my phone got too wet.
i got a new one today at Apple...however it is running 6.1.4
i had used cydia and saved all my blobs...
will i be able to downgrade to 6.1.2 and re-jailbreak?
dankduke
Sep 11, 2007
278
Austin, FL
Also here is what TinyUmbrella's information...
06/04/2013 16:20:12.097 Device connected: Duke's iPhone
06/04/2013 16:20:12.105 Loaded History...
06/04/2013 16:20:12.121 Loaded History...
06/04/2013 16:20:37.186 Caching shsh files...
06/04/2013 16:20:37.191 Found [0] shsh files to cache...
06/04/2013 16:20:37.194 Cached [0] shsh files
06/04/2013 16:20:37.198 You are using the current version of TinyUmbrella.
06/04/2013 16:20:37.672 TSS Server Started!
06/04/2013 16:20:37.683 TSS Accepting connections...
06/04/2013 16:28:27.866 TSS Server Stopped!
06/04/2013 16:28:27.883 Stopped TSS service!
06/04/2013 16:28:28.969 Started saving SHSHs for [Duke's iPhone]
06/04/2013 16:28:28.978 Started saving SHSHs for [Duke's iPhone]
06/04/2013 16:28:29.001 Duke's iphone-iphone5 6.1.2 (10B146) is already in progress!
06/04/2013 16:28:29.010 Duke's iphone-iphone5 6.0.1 (10A525) is already in progress!
06/04/2013 16:28:29.021 Duke's iphone-iphone5 6.0 (10A405) is already in progress!
06/04/2013 16:28:32.122 For version [iPhone5 6.1.4 (10B350)] - This device isn't eligible for the requested build.
06/04/2013 16:28:32.130 CYDIA DOES
NOT HAVE YOUR SHSH FOR iPhone5 6.1.4 (10B350) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
06/04/2013 16:28:32.233 For version [iPhone5 6.0.1 (10A525)] - This device isn't eligible for the requested build.
06/04/2013 16:28:32.250 CYDIA DOES
NOT HAVE YOUR SHSH FOR iPhone5 6.0.1 (10A525) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
06/04/2013 16:28:32.320 For version [iPhone5 6.0.2 (10A551)] - This device isn't eligible for the requested build.
06/04/2013 16:28:32.335 CYDIA DOES
NOT HAVE YOUR SHSH FOR iPhone5 6.0.2 (10A551) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
06/04/2013 16:28:32.459 For version [iPhone5 6.1.3 (10B329)] - This device isn't eligible for the requested build.
06/04/2013 16:28:32.470 CYDIA DOES
NOT HAVE YOUR SHSH FOR iPhone5 6.1.3 (10B329) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
06/04/2013 16:28:32.507 For version [iPhone5 6.0 (10A405)] - This device isn't eligible for the requested build.
06/04/2013 16:28:32.522 CYDIA DOES
NOT HAVE YOUR SHSH FOR iPhone5 6.0 (10A405) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
06/04/2013 16:28:32.699 For version [iPhone5 6.1.2 (10B146)] - This device isn't eligible for the requested build.
06/04/2013 16:28:32.711 CYDIA DOES
NOT HAVE YOUR SHSH FOR iPhone5 6.1.2 (10B146) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
06/04/2013 16:28:32.773 For version [iPhone5 6.1 (10B143)] - This device isn't eligible for the requested build.
06/04/2013 16:28:32.805 CYDIA DOES
NOT HAVE YOUR SHSH FOR iPhone5 6.1 (10B143) THERE IS NO WAY FOR YOU TO GET THEM. SORRY. YOU ARE JUST TOO LATE.
06/04/2013 16:28:32.818 Finished saving SHSHs for [Duke's iPhone]
06/04/2013 16:28:32.841 Caching shsh files...
06/04/2013 16:28:32.851 Found [0] shsh files to cache...
06/04/2013 16:28:32.862 Cached [0] shsh files
06/04/2013 16:28:32.893 For version [iPhone5 6.1.4 (10B350)] - This device isn't eligible for the requested build.
06/04/2013 16:28:32.904 CYDIA DOES
06/04/2013 16:28:36.278 Started saving SHSHs for [Duke's iPhone]
06/04/2013 16:28:36.485 For version [iPhone5 6.1.4 (10B350)] - This device isn't eligible for the requested build.
06/04/2013 16:28:36.509 CYDIA DOES
06/04/2013 16:28:36.530 For version [iPhone5 6.0 (10A405)] - This device isn't eligible for the requested build.
06/04/2013 16:28:36.538 CYDIA DOES
06/04/2013 16:28:36.710 For version [iPhone5 6.0.1 (10A525)] - This device isn't eligible for the requested build.
06/04/2013 16:28:36.726 CYDIA DOES
06/04/2013 16:28:36.753 For version [iPhone5 6.0.2 (10A551)] - This device isn't eligible for the requested build.
06/04/2013 16:28:36.763 CYDIA DOES
06/04/2013 16:28:36.893 For version [iPhone5 6.1.2 (10B146)] - This device isn't eligible for the requested build.
06/04/2013 16:28:36.904 CYDIA DOES
06/04/2013 16:28:37.075 For version [iPhone5 6.1.3 (10B329)] - This device isn't eligible for the requested build.
06/04/2013 16:28:37.090 CYDIA DOES
06/04/2013 16:28:37.128 For version [iPhone5 6.1 (10B143)] - This device isn't eligible for the requested build.
06/04/2013 16:28:37.162 CYDIA DOES
06/04/2013 16:28:37.175 Finished saving SHSHs for [Duke's iPhone]
06/04/2013 16:28:37.199 Caching shsh files...
06/04/2013 16:28:37.215 Found [0] shsh files to cache...
06/04/2013 16:28:37.228 Cached [0] shsh files
06/04/2013 16:28:58.477 Caching shsh files...
06/04/2013 16:28:58.489 Found [0] shsh files to cache...
06/04/2013 16:28:58.498 Cached [0] shsh files
06/04/2013 16:28:58.555 Loaded History...
06/04/2013 16:29:23.996 Started saving SHSHs for [Duke's iPhone]
06/04/2013 16:29:24.162 For version [iPhone5 6.0 (10A405)] - This device isn't eligible for the requested build
RoofMonkey
Jun 21, 2010
8,871
2,048
Sorry, but no you won't be able too :(
28,365
5,506
Moved to iPhone Jailbreak.
Unfortunately, the SHSHs are currently useless. The only option you have for jailbreaking is to try to find an iPhone 5 on eBay or craigslist that's running 6.1.2 or earlier and then sell your current one.
AdamDaieh
Jan 17, 2013
141
California
Sad to say you won't be able to downgrade to ios 6.1.2 and lower. Even though you have a SHSH blobs, it will still not work. As Europa said, you can but an iPhone on ebay and sell your current one. If not, we can only hope that there'll be a jailbreak soon. But I think the jailbreak will be release on ios 7. :(
