Will I lose data and apps if I upgrade jailbreak?
niranjan
Jul 12, 2008
I currently have a jailbroken iPhone 4 with firmware version 4.1. If I upgrade it to a newer firmware, will I have to reinstall all of my apps (jailbroken and regular)? Thanks for the help.
Gin
Tinman
4,334
183
Aridzona
If you update you won't use app store apps but you will of course lose jailbreak apps. Several tools can back them up for easy restore--I uses PkgBackup but that was about all there was when I bought it.
Michael
fijiman
Feb 13, 2011
832
64
UK
Gin
If you have your shsh files saved you can try to upgrade to 4.3.3fw, this is an untethered jailbreak...any higher, you will be forced into installing a tethered jailbreak,not good.....alternately you can wait till IOS 5.0 is released.
