Will i notice the difference between a 3G and a 3GS
Jul 26, 2011
As per title , i currently have a ipod touch 3rd gen which is quite fast runs all my apps fine , is there a huge difference in speed between them and will I have issue with the old hardware and new apps?
iNinja
Aug 8, 2008
3,985
20
UK
Yes, the 3GS is much faster and is still supported. The 3g isn't.
Iloveiphones
Aug 5, 2010
6,237
234
chatsocially.com
You are talking iPhones in the title, then iPods in here. Which one is it?
Jul 26, 2011
Well i currently have a 3g Ipod that i use more and more so thought i would get a iPhone instead
Dec 17, 2008
592
PA
I don't think you'll notice too much difference between an iPod touch 3rd Gen and an iPhone 3GS iPhone. We have a 2Nd Generation iPod touch it's just as fast as my wife's 3GS.
It often depends as much on the firmware it has.
Sent from my iPhone 5 using iCafe app
