will selecting "disable cellular data" prevent Apple from charging for a data plan?
May 16, 2010
previously i had been using an APN changer to avoid data plan charges. would selecting the new disable cellular data" option also prevent Apple from charging me a data plan?
iTim
Mar 21, 2010
445
Los Angeles, Ca
Apple doesn't charge for the data, AT&T does. As far as I know, you have to be signed up for a data plan on an iPhone. There is no way around it.
CyberData4
Jun 16, 2009
316
New York
No. That's just so you don't accrue hundreds/thousands of dollars of roaming data charges if you ever travel internationally.
May 16, 2010
well, AT&T has yet to charge me for a data plan since using the APN changer, so i'm a bit confused
