Will Summerboard work with 1.1.1?
x999x
Aug 6, 2007
1,656
I tried summerboard with my hacked 1.1.1, and it put my dock at the top, overlapping with some of the icons. Has anyone got it to work?
The install is a bit of a chore, but the beta does work!
Those little dots above the dock are pretty convenient, they show you how many pages of icons you have.
Hondamaker
May 14, 2007
9,939
665
55
Fairborn, Ohio
You have to manually install the Alpha version of 1.1.1 Summerboard, located here:
http://www.apptapp.com/summerboard/
I just manually installed the new summerboard, and it still puts the dock at the top, overlapping some of the icons. When I open Summerboard, it crashes. Since I manually installed it, I can't uninstall it with the Installer app. How can I get rid of it?
EDIT: Nevermind, I had set permissions wrong, so I changed them and all is ok with the world.
papabro
Jul 23, 2007
101
MA
ok I guess I need a little advise here. I did the manual install of summerboard using the instructions that came in the zip file. I have no scrolling, but I do have the SMB icon. When I press the icon I go to a blank grey screen with SummerBoard at the top. It stays on this screen for about 20 seconds and automatically pops back to the springboard. Any ideas? I did not do the "undo the previous Springboard patch" step in the instructions and I did not have SMB installed from installer.
Hondamaker
May 14, 2007
9,939
665
55
Fairborn, Ohio
Jarhead, make sure your permissions are set like this when you manually install summerboard:
rwxr-xr-x
The instructions say different, and it didn't work for me till I changed permissions.
papabro
Jul 23, 2007
101
MA
rwxr-xr-x
I've been out diggin holes in the yard and I was thinking to myself that it was the permissions. I thought it strange that it wasn't in the instructions. Even reread them several times to see if I missed it. Anyway thanks for the suggestion, it certainly helps to have the reinforcement. I am going to try it now.
ssjmonk
Apr 19, 2008
changing permissions
how the hell do you change the permissions if i used ibrickr and what should i change the permissions too if i used ibrickr
ssjmonk
Apr 19, 2008
