Will "windows mail" work with iPhone?
iphonenotify
Jun 6, 2007
420
This is the succesor to outlook. Its on windows vista, so i don't know if there will be problems between Apple software and the OS. Does anyone know what I should do?:oops:
iphonenotify
Jun 6, 2007
420
i actually need help on this one, please. Cause i don't know if i should start putting contacts on this.
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
That's an excellent question. I put all my contacts on Windows Mail this morning. I don't really want to buy MS Outlook just so I can sync my contacts with iPhone, but I will if I have to.
iphonenotify
Jun 6, 2007
420
BLAH... man, why did they have to make vista come with mail instead of outlook?:mad: So you run vista too?:eek: "wow" I thought i was the only one. "WoW"
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
You won't really know until you sync for the first time. I believe if you export your contacts as a CSV file, you'll probably be okay. I'll have to do some looking around in Outlook Express on my old XP machine to see what file we need.
iphonenotify
Jun 6, 2007
420
You won't really know until you sync for the first time. I believe if you save export your contacts as a CSV file, you'll probably be okay. I'll have to do some looking around in Outlook Express on my old XP machine to see what file we need.
Thanks, tell me what you get.
