WINScp and 1.1.2
Aug 28, 2007
348
when i use root and alpine my connection gets refused..
i really need this to work to put files on it, please someone help me, mobile fiinder isn't good engouh
enigmanic
Jun 27, 2007
513
When you ran the Dev Team jailbreak program, did you opt to install SSH? If so, you were given the option to change the password. That is the password you will need to enter instead of alpine.
Aug 28, 2007
348
i didn't install it, i didn't know what it was... what do i do..
enigmanic
Jun 27, 2007
513
That's okay if you didn't install it. All you need to do is install OpenSSH via Installer. Once you do that, just fire up WinSCP again and it should work with the password as alpine. If you still get a connection error, then you might be setting your phone's IP address incorrectly.
