WinSCP Help!
mflantin
Nov 29, 2007
100
I never really liked this program. I'm trying to Jailbreak my phone and it says to login to my phone using WinSCP so I can change the permissions on a file. I entered the IP Address, the login, pw, and for some reason, it won't let me connect to my phone. It says: Network Error: Connection Refused. Any suggestions on how to troubleshoot this?
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
SSH is probably not turned on. Try installing the Services app (under the Utilities category) - it lets you quickly toggle SSH and other services On and Off ...
mflantin
Nov 29, 2007
100
I couldn't find it in the Installer, so I installed it from iBrickr. Nothing showed up on the Springboard though. I also tried installing iToggle from the Installer, and when I click on the app, nothing happens...
mflantin
Nov 29, 2007
100
I also just installed BossPrefs which has a Services/Settings app replacement, and it does have the toggle feature but SSH isn't showing up. Maybe iBrickr 0.9 is not compatible with 1.1.3?
mflantin
Nov 29, 2007
100
You know what, I think that's the case, I just tried installing another app using iBrickr, and that didn't work. This must mean I still don't have SSH on my phone. I can't seem to figure out how to download SSH into my phone using Installer, I wonder why it's not showing up on my list.
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
I had some trouble with OpenSSH showing up in Installer immediately after running the dev team 113 Upgrader - but a couple restarts, refreshing sources etc. was all that was needed - are you definitely running current version of Installer as well?
mflantin
Nov 29, 2007
100
You know what, I gave up and restored my phone. Was running out of time at work so I'm going to give it another go once I get home. I was definitely running the current version of Installer too. Hopefully I'll have more luck doing it again at home. Thanks for the help and I'll post again later if I have any problems.
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
OK - good luck, hope it goes smooth for ya at home ...
