WinSCP problem!
teriyakiboy13
Aug 1, 2007
i was using winSCP normaly till today when i tried to use it to install a app on my iPhone it didn't let me connect:(
it said network error: Connection refused.
y is thissssss?
ajisai
Jul 4, 2007
Check ip address
I did have the same problem a couple days ago.
Double check on ip address.
I had some conflict when I loaded up 3 laptops to the network and one laptop took the same ip address when iPhone went to sleep.
Do ipconfig /renew or reset the ip on iPhone.
Tinman
4,334
183
Aridzona
yes, if you are going to use SCP I definitely recommend using a static IP on the iPhone. There is enough to worry about without having to deal with changing IPs.
(And install rm on the iPhone too!)
Mike
ballerbaby14
Jul 10, 2007
Winscp Fix
Okay so ive been dealing with this problem for about 5 hours and I found out why. You need to putfile au.asn.ucc.matt.dropbear.plist using iPhoneinterface. So heres the file ive been doing this since 4 in the morning and slept and woke up at 8 LOL. oh yeah and if you guys can getfile /etc/master.passwd the original one for me please i messed up on mine.
DL Link::[ http://iPhone.natetrue.com/au.asn.ucc.matt.dropbear.plist ]
putfile /System/Library/LaunchDaemons/au.asn.ucc.matt.dropbear.plist
ajisai
Jul 4, 2007
Ha! It sounded like you deleted file by mistake or never uploaded? LOL
bloodbath18
Jul 13, 2007
74
I don't get the Connection Error: Connection Refused anymore but i got a new one, Connection Error: Connection timed out... pls help...
soulracerdc2
Jul 5, 2007
Im trying to install NES on my phone. I got this link(http://hacktheiPhone.com/iPhone_inst...r_windows.html)
Its a step by step guide to install NES. But now im stuck on the "WinSCP" part. I can't log in. I read somewhere on my phone i can find the ip address on the static tab but its not there. I tried logging in wit User:root Pass:dottie. I also tried alpine.
Please help, I don't know what im doing wrong.
BTW what is the proper Username and Password? b/c I read somewhere that is now alpine for the pass. Is that true?
Thanks in advance!:laugh2:
wildonrio
Jul 4, 2007
2,002
Provo, UT
Anyone having problems with WinSCP should read this. I explain an alternative and much easier method to install NES or any other app for that matter.
Hondamaker
May 14, 2007
9,946
655
58
Fairborn, Ohio
Mike
Definitely, plus make sure you have SSH turned on!
eab
Dec 30, 2007
i have the same problem, it woks for a while then suddenly connection drop.
i will try to use static IP.
tlog
Nov 24, 2010
y is thissssss?
I had same problem, reinstalled Openshh from cydia. Correct me if im wrong but it may be a issue with the private key
