Winscp
ob123
Jul 3, 2007
29
I have jailbreak running but when i try to run winscp i get this
my firewall is off.
i have ssh running
i have seen other people have had this problem but have not found an answer please help!
sublime
Aug 18, 2007
Security Program Running
I had the same problem then I found out that norton anti virus/firewall was the problem. I uninstalled all norton application and it is now working fine.
my firewall is off.
i have ssh running
ob123
Jul 3, 2007
29
ya i uninstalled norton and im still getting the same problem, is there another program i can use instead of this?
x999x
Aug 6, 2007
1,656
If you've got a firewall or router, make sure you've got port 22 open. You may also need to port forward port 22 to your desktop's IP address.
22 should be open already, but if you're having problems, it's worth a shot.
soulracerdc2
Jul 5, 2007
Please Help! THanks
Im trying to install NES on my phone. I got this link(http://hacktheiPhone.com/iPhone_install_nintendo_emulator_windows.html)
Its a step by step guide to install NES. But now im stuck on the "WinSCP" part. I can't log in. I read somewhere on my phone i can find the ip address on the static tab but its not there. I tried logging in wit User:root Pass:dottie. I also tried alpine.
Please help, I don't know what im doing wrong.
Thanks in advance!:laugh2:
Kathie63
Mar 15, 2009
414
Wisconsin
I just got the 3GS and jb it today but when I try to get into winSCP it won't let me connect. it tells me network error:connection refused
When I had my 3g I had no problems what so ever. I do have the correct IP address and user name and password, same as before. HELP
iphonewarrior
13,847
699
Do you definitely have openSSH installed..? lol. :sneaky:
PW: alpine
patrickj
Sep 2, 2007
6,221
407
Austin, Tx
ipadinsight.com
I did a post on this at my site a while back with a little troubleshooting checklist. Might not be of help for you, but just in case ...
Things To Try If You Cannot Connect To Your iPhone Via SSH:
  • If you get a timeout error, try increasing the timeout setting
  • Make sure SSH is turned on, on the iPhone - Generally the easiest way to do this is to use an app like SB Settings that gives you a GUI interface to toggle the service on and off with.
  • Make sure WiFi is turned on, on the iPhone – again, via SB Settings or the iPhone’s built-in Settings Applet.
  • Check that you are specifying the right port in your desktop SSH app (e.g. WinSCP on Windows or Cyberduck on Mac). The port needs to be 22.
  • Make sure you are entering the correct – and *current* – IP address for the iPhone. If your iPhone gets a DHCP (dynamically configured) IP address from your router (as most do), then its address can and will change over time. So its IP address today may be different to the one it had last week when you last successfuly connected. To check this go to Settings > WiFi – and tap on the blue arrow next to your active WiFi connection – the screen that takes you to will display the iPhone’s current IP address.
  • Verify that the iPhone has a *valid* IP address. When you are checking the address per the above point, if you see an address that starts with 169.254.x then the iPhone is not getting a usable IP address – and you need to troubleshoot that issue first.
  • Remember that the iPhone and the PC you’re tying to connect from must be on the same WiFi network. One of the easiest ways to tell this is to see if their IP addresses look similar. For instance, many default home WiFi networks will have IP addresses that start with 192.168.x.
  • Check that you do not have any antivirus, firewall, or security software on your PC that may be blocking your outbound SSH connection. One of the easiest ways to quickly rule this out (or pin the blame on it) is to shut down any and all of those services on your PC temporarily and try connecting. If it still fails, you know those services are not to blame.
  • Password check – you need to be using the correct username and password for connection to the iPhone. If you have never changed these (which the vast majority of iPhone users have not – and you would know if you did) then the most likely defaults are username ‘root’ and password either ‘alpine’ or ‘dottie’. Please note – you do not type the ‘’ inverted commas around the username or password.
  • The iPhone cannot be in ‘sleep mode’ when you are trying to connect. You may just want to change your Auto-Lock setting to ‘Never’ just for while you are connecting – to avoid this issue.
  • Make sure you are using the correct protocol setting in your desktop SSH app. This varies according to which client app you are using. WinSCP uses SCP, for example.
Kathie63
Mar 15, 2009
414
Wisconsin
I looked on my phone for the ip address and the computer, the addresses are the same except for the last number. the computer has 11 and the phone has 13 otherwise the address is the same. where do I find the SSH on my phone?
