WinterBoard Options
blazew0n
Aug 19, 2008
121
What happen to all the options in WinterBoard? i noticed a couple new thing but many others are missing?also one of the options say "no unlocked labels" and another says : no UNOCked labels" ? Which doesn't seem to do anything?
Edit... figured it out.
blazew0n
Aug 19, 2008
121
You just have to look for winterboard options and install them, the easy way is throught cydia, like if you dl say custom sliders, you will see it as an option in winterboard. Guess they removed what they thought wasn't necessary but you can easily get them back through cydia.
