Winterboard Theme Help
musser15
Jan 25, 2012
Ohio
OK I am new to all this and thx for any help here.
I downloaded Penn State theme off Cydia and installed it, no problem. I like everything about the theme except the background when the text screen comes up (using Bitesms, but it the same background for the stock text). The background makes it hard to read the text.
Question:
I want to leave everything with the theme the same, except change the background for the text program. Is there a way to pick through the theme and do this?
I am not too technical when it comes to computers. Thx.
iFile will give you access to the file system on the phone itself, or you can use iPhoneBrowser, DiskAid or SSH. Navigate to Library > Themes > Penn State and look for the wallpaper. You can then delete it and replace it with another.
