Woke up this morning, battery was run dry..
Charlie
Finally was activated last night, which is of course, awesome. Played with it, put my songs on it, messed with the internet and went to sleep.. Woke up this morning and the battery was completly drained. (Wasn't plugged in my computer, have you)..
Anyreason this happened? Was it running something while it was locked.
Kind of scares me that it happened like that!
Any thought?
-Charlie
mp78
Jun 27, 2007
maybe plug in the dock? thats a good place to start
there should be no problems with charging
Charlie
After so many seconds the backlight goes off on mine too.. says 1 minute to lock or whatever..
I don't know, it worries me! :(
mp78
Jun 27, 2007
if you have problems, do a restore through iTunes...you can always resync your info.
JnC
Jun 17, 2007
333
Yeah my battery was depleted by an additional 25% this morning too.
I think one problem may be with the email settings. If it's set to autocheck frequently, then it's doing that all throughout the night. I wish there was some way that the phone would not check email by default for what you specify to be a "quiet time".
Charlie
I did set up my gmail last night... That may be the issue then..
Hrm, you're right though.. that needs to not do it ><
mp78
Jun 27, 2007
i have my gmail and .mac checking every 15min and my batt life is great. lovin compared to my brick treo.
now if i can only get my low volume issue solved
JnC
Jun 17, 2007
333
Also it would be nice if the phone is sleeping if it would turn off the WiFi if it doesn't already.
DigitalEndorphins
Jun 19, 2007
34
fyi, in case you don't know...
you can set your email to manual check in the settings/mail button.
that will help with your battery drain.
Fafafoooey
Apr 26, 2007
120
Guy, and gals, remember that you need to allow a few cycles of charge and discharge to gain the full power capacity of the battery. Give it a month's worth of usage, then let's see what happens. Worse case, you get a replacement from Apple. But give it time.
