Won't connect to WiFi ? Please help
Smiffy403
Dec 24, 2011
30
Hello, my father in law has an iPad 2 as per the title but it won't connect to the wifi but my iPad will ? Any 1 got any idea what could be wrong ? Thanks Dave 8)
Sent using iCafe app
liberated
Jul 19, 2007
3,238
484
I know it sounds silly but make sure airplane mode is off and wifi is on in settings.
Smiffy403
Dec 24, 2011
30
yes we've tried that thank you, and thanks for the speedy reply but it's worked fine up till when I brought my 4th gen today (i think ) and connect it to the net and now it seems to not work lol I'm sure it's not connected lol just a bit of a coincidence lol
JON35Y
Oct 16, 2012
87
Try a reset on it I would. Hold down power button and home button till it switches off and back on. As soon as you see the Apple logo let go of both buttons and try connecting again....
Sent from my iPhone 5 using Tapatalk www.twitter.com/The_Real_JON35Y
Smiffy403
Dec 24, 2011
30
Sorry should have said I've done this a few times but to no avail 8(
JON35Y
Oct 16, 2012
87
Restore then?! If all the settings are correct and a restore doesn't fix it then surely it's a hardware problem? Have you tried to disconnect the working iPad from the router and then try?
Smiffy403
Dec 24, 2011
30
Yes we did try that too can't seem to work out whats coursing it ? It's worked fine up till now
Docd
Oct 16, 2011
651
62
Have you tried resetting network settings and tried it on another wifi?
iPutz
Nov 20, 2012
964
183
43
74
US Midwest
Try temporarily turning off the security settings on your WiFi router (make it an OPEN network) and see what happens. If the problem device connects to an open network then go back and review your security settings on both the router and the problem device. Is your WiFi router set up to supply a sufficient number of IP addresses for all of your WiFi devices? Some routers are set-up to dole out IP addresses within a specific range, exceed the number of addresses available and the last device to try to connect may not be assigned an IP address by your router and thereforee will not be connected . Let us know if you come up with an answer.
