Won't let me restore phone
chazm
May 1, 2008
729
40
Ok, I must be doing something wrong here.
I have a JB 1.1.4 and I disabled updates a few days ago so that I wouldn't brick my phone with the new update.
Now, I want to get 2.0 so I click "restore" but when I do it says "automatically checking for iTunes and iPhone updates is disabled. Would you like iTunes to check for a new iPhone software update?"
I can click "check" or "cancel". I clicked cancel and nothing happens.
What do i do to restore?
styfle
Mar 31, 2008
3,381
what are u trying to restore to? 1.1.4?
chazm
May 1, 2008
729
40
well i have 1.1.4 and jailbroken but i have to restore before i update, right?
24trepid
Jan 13, 2008
502
I would restore to a fresh 1.1.4, not jailbroke.
Then upgrade to 2.0
I hope you haven't upgraded iTunes yet.
If you have already upgraded to iTunes 7.7, then all you can do is
just upgrade to 2.0
Hope this helps........:cool:
chazm
May 1, 2008
729
40
Then upgrade to 2.0
just upgrade to 2.0
Im confused
I am trying to restore to a fresh 1.1.4. It wont let me, its making me check for updates first to upgrade iTunes. Should I just let it update even though my phone is still jailbroken?
24trepid
Jan 13, 2008
502
Yeah, you should be fine. Just set up as a new phone on the 2.0, just to make sure it wipes everything clean. So no traces of your jailbreak will
remain on phone.
chazm
May 1, 2008
729
40
remain on phone.
thanks, ill try it.
**crosses fingers**
