Wrong album artwork
Hack
Aug 23, 2011
9
iPhone is displaying wrong album artwork... Any ideas how to fix that? I have about 20 albums with the same artwork...
iAndy
Apr 8, 2011
21
Is the artwork correct in iTunes? Have you tried to remove the songs and resync? Is the artwork from iTunes that you've bought? Or art you've added to your own music?
Rugaby
Feb 18, 2011
7,122
1,172
Washington state
I once moved a bunch of songs in windows media player all to the same album. I then transferred the music to iTunes. Because the original path name had the same album listed it would show that album artwork in iTunes. I figured it out and move the songs to iTunes from the original albums and then the artwork was correct.
Syamil
Jan 31, 2011
296
Singapore
U can fix em manually by right clicking on each album and go to 'Get info'. There would be a tab for artwork, where you could easily add or delete album art as if it's your own song that you created.
Hack
Aug 23, 2011
9
The albums I purchased through iTunes are the ones with the wrong artwork...
Bennyboy
Jul 21, 2010
14,017
1,731
PA
I'm running firmware 4.2.6.
Plug in your phone, uncheck all of your music and sync your phone, this will take all your music off your phone, re-sync and see if that helps, if that doesn't help update your phone to the latest firmware, that did it for me. All my music on my phone is directly from iTunes, I had bunch of songs that always showed a blue October album cover. Nothing worked other than the update. If you're jailbroken and the first advice doesn't work and you don't want to restore and re-jailbreak just deal with it for now.
Hack
Aug 23, 2011
9
Do I have to sync my iPhone to the original computer I synced it with... Or can I use a different computer?
Bennyboy
Jul 21, 2010
14,017
1,731
PA
Whatever computer you use to sync your phone with.
Transfer all your purchases first, click on where it says "file" and select transfer all your purchases from whatever your name is iPhone, then uncheck your music from the iPhone summary tab, hit sync.
Booyow1204
Jul 14, 2010
595
40
Las Vegas
That happens to me sometimes...I usually just continue what I'm doing and eventually it goes away/resets itself. I don't really know how or why it starts, but it usually doesn't last that long.
Booyow1204
Jul 14, 2010
595
40
Las Vegas
Ok thats weird, when it happens to me it's usually when a song is playing, and when I'm on the artist track screen....maybe try deselecting those albums that appear to be affected and syncing, then re-syncing those certain albums, obviously it's not your whole library so it appears to be just something going on with those specific ones.
