x999x Question!
Tsn223
Mar 17, 2008
85
Chicago, IL
I noticed that the repo text document you use is quite different from the one I use. I was wondering if you could post a link to a blank repo.xml doc you use. I would like to give that one a try if at all possible. And if its not to much trouble like instructions on how to use it. I know its a lot but I really really want to get this source up, but I keep getting errors. I even looked at how yu zipped your files on your mac, I did the same thing with still no luck. Thank you in advance.
Tsn223
Mar 17, 2008
85
Chicago, IL
The only reason I ask this, and I hope your not mad, but I took your leopard theme. Downloaded the theme right from your "website" and plugged it into my repo source info. And I get a mainscript exectuation error. But you use the same one and it works. This leads me to believe its my repo text. I would just like a copy of yours and instructions on how to use it to see if it works. Or if you can think of anything that could cause a Main Script Execution Error.
Tsn223
Mar 17, 2008
85
Chicago, IL
Heres the repo text I use. The first one has been edited by me. Its the one I used for your leopard theme to test. The second is a blank one.
CBRfanatic
Feb 28, 2008
302
Bronx
if its just 999 your looking to talk to, better off pm'ing him.
x999x
Aug 6, 2007
1,656
Hi, let me get some stuff together. I just got back from the gym, then a dance class and I'm pretty exhausted. Hopefully I can have this for you by midnight.
x999x
Aug 6, 2007
1,656
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>info</key>
<dict>
<key>category</key>
<string>999's sandbox</string>
<key>contact</key>
<string>misc.repo999@gmail.com</string>
<key>description</key>
<string>999s Sandbox</string>
<key>maintainer</key>
<string>666 aka 999</string>
<key>name</key>
<string>Sandbox</string>
<key>url</key>
<string>http://www.dezign999.com</string>
</dict>
<key>packages</key>
<array>
<dict>
<key>author</key>
<string>x999x</string>
<key>bundleIdentifier</key>
<string>com.dezign999.rngitch</string>
<key>category</key>
<string>Fight Club</string>
<key>date</key>
<string>1206949787</string>
<string>Pulled from the Commercial</string>
<key>location</key>
<string>http://dezign999.com/iPhone/iPodTouchJingle.zip</string>
<key>name</key>
<string>RNG: iPod Touch Jingle</string>
<key>scripts</key>
<dict>
<key>install</key>
<array>
<array>
<string>CopyPath</string>
<string> iPod Touch Jingle.m4r</string>
<string>/Library/Ringtones/ iPod Touch Jingle.m4r</string>
</array>
</array>
<key>uninstall</key>
<array>
<array>
<string>RemovePath</string>
</array>
</array>
</dict>
<key>size</key>
<string>439484</string>
<key>version</key>
<string>1.0</string>
</dict>
</array>
</dict>
Heres a copy of my Beta repo. You should be able to copy/paste it into an xml document and have it work just fine.
