Xp service pack 1 with iTunes ?
Mar 12, 2008
22
Please help... :confused:
I have service pack 1 installed ( XP professional )
Is there any version of iTunes I can download / use with my iPhone without having to upgrade to service pack 2 on my pc?
OJsakila
Jul 15, 2007
3,021
Jupiter's sulphur mines
why don't you want to go service pack 2?
Seems to me that's your best bet. I don't see why you can't do this unless you are on dial-up or something...
Mar 12, 2008
22
I have XP service pack 1 running on a laptop - used for work purposes and I have been using iTunes until now without any issue. The issue I have is that service pack 2 is not necessarily supported by all current applications on my laptop (or at least would have to be tested by my company before I can upgrade safely to sp2) so I just want to know is there any way of running an iTunes release without having to go to SP2
scholls22
Jul 15, 2008
58
did you ever find a way to use SP1 with iTunes? im having the same problem as you....
Mar 12, 2008
22
Afraid not - I had to bite the bullet and upgrade to SP2
Worth it though and my laptop is fine post upgrade to.
