y applications crash while listening to music
alb0zf1n3st
Jul 2, 2007
624
There is a bug in the phone.. hopefully the update will fix it.. and hopefully its soon
alb0zf1n3st
Jul 2, 2007
624
Try to turn off the phone or do a reset i think its Sleep botton and the Home botton hold for about 10 Sec but google it or search forums.. not 100% sure
Michael Baturin
Jul 11, 2007
1,751
244
34
South Jersey
Prediction...
Im guessing to fix this they will have a close out button for each widget. See what happens right now is say you use your map. When you go back to the home screen to go on safari, that map you were just looking at is still running.
Say you then open up 5 safari windows, they are all still running plus your map. Also say you had youtube opened from yesterday, also still running. Because all these run at the same time, (plus the music), the phone can not handle the task at hand (maps, safari) and it justs returns home. Is this better than just shutting off, hell yes, but annoying non-the-less.
My prediction is for the update, they will have some functionality to quit maps or end your session or something like that. This way you wont have tons of "tabs" open whilst doing other things.
