Yahoo - Able to Receive but not Send
DrVest
Jul 3, 2007
17
Does anyone else have this problem? Emails sent to me are pushed to the phone like clock work, however; when I reply back they seem to be getting lost and never arrive to the recipient.
Thoughts?
509vista
Jul 3, 2007
Yes I just had this happen to me today (multiple times). I have yet to successfuly send an email, have you (anyone)?
EDIT: I'm thinking that it is only today that it is not working but i cant be certain because this is the first day that have tried to send an email.
mikef1182
Jul 2, 2007
44
Thoughts?
This seems to be a major issue affecting many users. I have found if I do a soft reset (home button+sleep button for 10 seconds) it restores normal behavior.
wjp09
Feb 25, 2007
2,559
25
NJ
Thoughts?
I had the problem and then it resolved by itself
Ace4261991
Jun 18, 2007
530
nope its been not working for me since day one.
CMatthews
Jul 4, 2007
Texas
I had the same problem and was able to get it resolved by turning on SMTP.
http://docs.info.apple.com/article.html?artnum=305634
Apparently this is only accessible if you set up as POP/IMAP account manually, using not the automatic IMAP Yahoo settings. Mine worked fine for 3 days then yesterday the sending issue hit me, Yahoo must be having problems, hopefully they'll get it straightened out.
jeffoest
Jul 10, 2007
I have the same issue. Interestingly I've found the following dynamics:
1) if you go to your yahoo account on your computer and send a test message somewhere from it, it seems to "activate" the account again on iPhone which allows it to send email from that account (for a little while).
2) when you first enter a new yahoo account, it seems to work (for a little while) until it stops pushing and sending.
My hunch: (could be wrong)... Yahoo! is having trouble with authenticating on it's outbound server after a certain "timeout" or lag or Apple is not sending the authentication correctly... Frustrating. It's really the only thing on my iPhone that I've found that just doesn't work.
stiphone
Jul 10, 2007
76
Tucson, Arizona
I'm experiencing the same problem and can't seem to resolve it. It was working fine when I set it up a couple of days ago and it suddenly stopped working. This is fustrating cause now I have to use another account just to reply mails. I'm gonna try a soft reset and see if it works and hope I don't loose my mails.
luckfam
May 31, 2007
After sending a message go to the "sent" folder and open it. You will see at the bottom of the screen the message "downloading message". It will send after that. I don't know why but that is what I had to do all day Sunday and Monday. I really hope that yahoo fixes this or they offer push gmail. Try what I did and see if it works for you and let me know. Interested to know if it does work.
mikef1182
Jul 2, 2007
44
After I send a message it doesn't even show up in my "sent" folder. It makes the send sound and goes into email oblivion. I haven't been able to send an email from my yahoo in about a week. Very very frustrating! I gave up my exchange server for this crap.
luckfam
May 31, 2007
Wait a couple of seconds-you will see the message "checking mail" then "downloading mail" after the message downloads it will appear in your "sent" mail. Try again and let me know.
mikef1182
Jul 2, 2007
44
Your right it now shows in my sent box (for the past week it never did), but sadly even after I open it and it says "checking mail" It never actually sends. I have sent myself emails to both my .mac mail and my work mail to verify. No mail has come in for either account.
luckfam
May 31, 2007
I just tried and now yahoo seems to be working perfectly! I sent a message to my gmail account and it came through immediately. Keeping my fingers crossed that it will continue to work.
stiphone
Jul 10, 2007
76
Tucson, Arizona
it's still not working for me. After sending the mail, I went to the sent mail folder and waited. I also tried checking mail but it just doesn't appear and the sent mail just disappears. This is fustrating as I used to have an exchange mail and I don't encounter these problems. Hope it works though as I'm now using my gmail. Giving up on yahoo mail soon. :(
DaMango
Jul 11, 2007
Mine also was not working. I receive emails no problem, but cannot send. If you go to settings, I'm sure your email address and password is correct, but did you happen to change your account name to something different? For example, instead of what yahoo has in Jon Doe, you put in JD?
After correcting mine, no problem, I now send emails. Hope this helps!
