J jstemp33 New Member Jun 20, 2007 27 0 0 Jul 6, 2007 #1 Do I setup the yahoo email using the icon in the iPhone or can I setup through the IMAP process on the iPhone? Does it matter? If IMAP, what are the settings for the incoming server/outgoing server? PLEASE HELP!
pb30 New Member Bronze Jul 1, 2007 81 0 0 Minnesota Jul 6, 2007 #2 Use the Yahoo setting, it's the only way to get IMAP
J jstemp33 New Member Jun 20, 2007 27 0 0 Jul 6, 2007 #3 pb30 said: Use the Yahoo setting, it's the only way to get IMAP Click to expand... I did, It seems to me that when I send a message, it does not go into my sent folder so I am not sure it was sent. Any thoughts! Is this a yahoo problem as of now for the iPhone?
pb30 New Member Bronze Jul 1, 2007 81 0 0 Minnesota Jul 6, 2007 #4 Under Settings - Mail - Yahoo - Advanced - Sent folder, is it set to the folder on the server or on the iPhone?
J jstemp33 New Member Jun 20, 2007 27 0 0 Jul 6, 2007 #5 pb30 said: Under Settings - Mail - Yahoo - Advanced - Sent folder, is it set to the folder on the server or on the iPhone? Click to expand... What should it be set too? Mine is set to the server! Does this apply to all folders (drafts,deleted)
