Yahoo Imap Question
DUKEL
Jun 27, 2007
646
S.D. CA 92109
I know yahoo IMAP is not desktop compatible but I have heard people claiming that since the iPhone uses imap-idle for push that I can manually enter or set up IMAP with my free yahoo account on the iPhone. I've been having problems receiving email from push so I am trying to set it up to auto retreive every 15 min through imap. I thought I had remembered seeing a option in the yahoo acct settings to check every 15 mins but I don't see it anymore. Maybe the option was taken out with 1.13.
Does anyone know where the option is to set up auto check every 15 mins. or the IMAP settings for the iPhone so I can manually set up my yahoo account? Thanks for any help.
thesaint
Jul 9, 2007
341
DFW
Go to Settings>Mail>Auto-check and set the desired time frame.
DUKEL
Jun 27, 2007
646
S.D. CA 92109
I went to Settings>Mail... but there is no auto check. I think the option was taken out in 1.13 as I mentioned in my above post. Are you actually able to go settings>mail>autocheck on your yahoo acct?
thesaint
Jul 9, 2007
341
DFW
You don't have the option in when you enter Yahoo mail and its not removed in 1.1.3. I can still see it. Do this, go to Settings and then click Mail, now scroll down after all your mail accounts, under Messages header the first things is "Auto-Check" before "Show". Click on it and you can select the different option(s). Let me know if you cannot find it.
thesaint
Jul 9, 2007
341
DFW
More info...
DUKEL
Jun 27, 2007
646
S.D. CA 92109
Mine does not have the auto check feat. It has show, preview,minimum font size etc. How did you set up your yahoo acct, By pop, imap, or automatic settings?
Edit. Okay I figured it out. I first had to turn off push and then the autocheck option magically appeared! How has your experience been using this IMAP auto check. Has it been a lot more reliable than the yahoo push email? Thanks.
thesaint
Jul 9, 2007
341
DFW
I don't use Auto check or the push. I was using it earlier, but it was eating away my battery quite a lot. Hence, I have set the Auto-check to manual.
DUKEL
Jun 27, 2007
646
S.D. CA 92109
Okay. I guess time will tell. Thanks for the help..
