Yahoo push e-mail problem
jareknyc
Aug 27, 2007
715
NYC
:sick:My iPhone was working for like 1 week with the yahoo e-mail now im trying to get e-mail download them or refresh bottom and its not going anywhere for like 4 days already i don't know whats going on please help guys
thanks
420greg
Jun 26, 2007
845
Orlando, Florida
thanks
Log in to your yahoo account on the web from your pc.
When ever I have trouble with yahoo on my iPhone, logging in to the website seems to fix it for some reason.
rwnewton
Jul 11, 2007
21
I'm with you brother -- i've had many problems with yahoo email push. I picked up this process here and it usually gets yahoo to start sending email agian.
1. log onto your yahoo account from your pc and move all messages in your inbox into a temp folder you set up.
2. delete your yahoo account on the iPhone and set it up again.
3. log onto your yahoo account from your pc and move the messages in your temp folder back to the inbox.
hope this helps.
daziphone
Jul 4, 2007
62
Columbus OH
hope this helps.
I am having problems also. I get NO mail from Yahoo! I did all the steps as you suggested but no good I sill do not get any email?
I'm beginning to feel that the Yahoo (push email) just flat doesn't work most of the time. :(
Venkat
Sep 8, 2007
Push is not working for me....
I bought the iPhone just few days back..
Yahoo Push is not working for me. I tried all the steps mentioned here..
Has anybody got Push email working?
510039
Jul 12, 2007
19
I've had trouble as well. Don't know if its an issue with the phone or yahoo. My guess is yahoo, cause I got so tired of it I went to gMail and that works like a champ for me. I still get email to my yahoo account and its still set up on my phone. I might go 5 days without getting any yahoo mail, and then I'll get 25 at one time.
The fix... Switch to gmail!
roachsocal
Sep 12, 2007
fix is coming for Yahoo! push email problems on iPhone
Hello everyone. I just got done speaking with one of the Yahoo! Mobile Technology folks at Yahoo! and they were able to verify that this is a known issue in which the resolution lies with Apple. They have advised that the next iPhone software update from Apple is designed to fix these 'Push' issues that we're all encountering. Due to the severity of the issue this update will likely be coming soon so keep your eyes open.
soumenb
Sep 18, 2007
That worked!
hope this helps.
Thank you! I was having the same issue, but following your procedure worked. Thanks again.
LM0316
Aug 21, 2007
It's funny... I went yesterday to the Apple store to talk to a "Genius" about this "push" issues and he told me that the problem was Yahoo, and that they (Yahoo) are working on the "bugs" to fix this issue.
Hopefully somebody does something, this problem is ANOYING
awah
Sep 17, 2007
The Yahoo push is working. You need to select POP and use the pop.mail.yahoo.com when you setup the mail account on iPhone. Do not use the preconfig Yahoo MAIL, use the other MAIL and set it up as POP.. Then, the push will work. However, this is only for paid yahoo account or other premium yahoo account. Free yahoo mail account does not offer POP service.
The IMAP for yahoo is from Apple. That's why the server is imap.apple.yahoo.com and is only available through' the iPhone. However, IMAP setup allows the phone to download all the mail folders besides InBOX.
The yahoo pop server only allow downloading the inbox but the push is working though. So, you can choose either one if you have yahoo POP access.
bionic3
Jul 3, 2007
This works, I have tried it following the 1.1.3 iPhone update from 1/15/2008:
Delete then recreate account Go to the Settings application, tap Mail then tap your Yahoo! account and tap Delete Acount. Then go back to the Mail pane of Settings and re-establish your Yahoo! account. You may need to reset your iPhone again after doing this.
After this mails come in instantly to your iPhone via Yahoo Push. For some reasons Yahoo accounts configured on your phone prior to the iPhone update or launch of Yahoo Push will not realize the benefit. It is a slight annoyance to have to recreate accounts, but it does correct the problem.
kokogirl
Sep 8, 2007
2,319
49
Sunny Florida
I am having problems with the Yahoo push, so I tried your method. Did you set up the email with the Yahoo link thing in the settings, or did you set it up manually? Also, on the iPhone settings for mail do you have it set for auto check manually, every 15 minutes, or 30 minutes, etc? Thanks for the help in advance. I can live without the Push working, it just bugs the heck out of me that is does not!
If it makes a difference, I am using a yahoo account that is myname@mydomain.com , not the name@yahoo.com email address.
bionic3
Jul 3, 2007
Sorry for taking so long to get back to this. I set my mail up with the Yahoo link in Mail Settings. I used the 15 minute auto check, but with Push enabled my mail now comes through instantly. I find that some mail sources still have latency, but that is them sending to Yahoo. Test from a gMail account as I found it to be the fastest web-based mail delivery around.
I hope this helps!
kokogirl
Sep 8, 2007
2,319
49
Sunny Florida
I hope this helps!
No problem on the delay. I appreciate the help. I think part of the problem is the Yahoo bizmail. I read on the Yahoo website that the bizmail is not a normal or regular Yahoo account. I set up my yahoo bizmail on my iPhone using the POP set up that Yahoo outlines. I then got my em on the iPhone, and it fixed the problem I had before where I could not send em from the iPhone. But with POP you cannot get all of your folders on the iPhone and it does not sync like my gmail IMAP. I was also getting lots of errorrs while using the em on my computer. I ended up totally deleting the yahoo account off my iPhone right now. I wrote an em to Yahoo bizmail support. Maybe they can help.
