YouTube Problems
alansmith
Oct 23, 2011
27
Hi All
Im trying to go on youtube and it says cannot to you tube?
Is there any solutions to this?
alansmith
Oct 23, 2011
27
im connected to wifi at the moment and it keeps on saying the same message, cannot connect to youtube
iBoss
Oct 15, 2011
250
53
this usually works for me when im at work. I close the youTuube app on background turn OFF the wifi on settings, then turn off my phone completely. when i turn it back on just turn the WiFi back on and go to you tube and try it it usually helps me. hopefully it helps you..
iBoss
Oct 15, 2011
250
53
just wanted to ask you if you got the problem fixed? and if you did what did you do?
blastewitz
Feb 3, 2011
51
39
Bognor Regis
is it a jailbroken iPhone and which iPhone ? mine is a 3g and after jailbreaking I was using cydia for this problem in particular and there is a repo which I can't remember but google for "pushfix "and you should get sum pic about what to do.
