YouTube quality
tupacinla
Jul 5, 2007
51
does anyone have a problem with the video quality on youtube? When I am at my friends house the quality is prestine but at work it is really bad quality.. I tried the same videos to see if that was the case but its not.. Does anyone else have that problem?
alb0zf1n3st
Jul 2, 2007
624
I could have swore I heard that if you use EDGE the quality is different then WiFi but don't take my words for it.. I have noticed different quality tho different areas I wonder why tho its all the same videos.
wildonrio
Jul 4, 2007
2,002
Provo, UT
Yeah, that's true. If EDGE is running, YouTube is horrible. Make sure you're on WiFi.
dennismccarthy
Jul 14, 2007
Definitely different performance when using wifi
I can't get YouTube to play more than 10% at all when using my wifi. They work great on Edge. I think this is a genuine bug.
bw2151
Jun 25, 2007
31
so I posted my first you tube video and I just noticed that if I watch it via 3G it's all pixely, but it's very good via wifi.
So where is the quality dropping? The iPhone or does YouTube do something?
dturner
Dec 15, 2007
5,725
Louisville, Ky.
Wifi is generally faster than 3G. So if you are in a weak 3G signal area, the quality is not going to be as good. Actually in a strong 3G signal it still may not look as good as on wifi.
psylichon
Oct 31, 2007
16,591
751
42
Philly
Youtube encodes every video at two qualities... broadband, and mobile. Unfortunately, 3G, while faster than Edge, still falls under the slower category, so you'll see the same video you'll see on Edge. You'll just see it faster.
jarofclay73
Jun 23, 2008
2,387
Honolulu, Hawaii
It's interesting because the Now Playing shows trailers at Wi-fi quality on the 3G network. And it plays fine. Too bad YouTube intentionally downgrades it.
SweepeR
Oct 1, 2007
367
Is it me or does the quality of videos suck on the iPhone? My friend has that google tmobile phone and it's 29823 times better. Is there a way to watch decent quality YouTube clips?
3G Unrestrictor (Cydia app) will enable high quality YouTube videos on 3G.
3G Unrestrictor allows you to use apps that are WiFi only on 3G. You have to jailbreak to install it. It should work with FaceTime once the iPhone 4 is jailbroken. Apple allows high quality YouTube videos on WiFi only, this app allows you to view them in high quality when you're on 3G. It also lets you download apps that are greater than 10 MB over 3G. That's normally restricted to WiFi only.
SweepeR
Oct 1, 2007
367
That's sickkk. How do ppl jailbreak iPhone 4 I haven't since the very first iPhone
redneck47441
Jun 3, 2009
120
Get free app Truveo from app store then after it downloads go into settings and turn on allow cellular access and there you go!
