ZiPhone Vs Quickpwn
Sneekz
Jan 2, 2009
Which One do YOu Suggest To Jail Break my iPod touch
Is there any Others
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
What firmware are you running / planning to jailbreak?
If it's latest, I think you need to use Pwnage Tool / Winpwn - as ZiPhone has never been updated for the 2.x days.
Sneekz
Jan 2, 2009
Soory i Mlate On The Reply 2.2
ess_bee
Dec 16, 2008
152
UK
OK - then as per above, I don' think there is any ZiPhone version that will work on 2.anything. Think you need to look at Pwnage / Winpwn
Zi-Phone didn't work for me? It kept putting my iPhone into restore mode and it freeze. My iPhone wouldn't do anything or move off the screen until I restored it :'(
Pwnage is the software I used and worked fine
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
As above, ZiPhone has not been updated at all since 2.x firmware arrived, and shows little to no prospect of being updated as Zibri is selling the domain etc that his ZiPhone blog runs on ...
styfle
Mar 31, 2008
3,381
Let me rephrase what is stated above....
YOU CANT USE ZiPhone ANYMORE :)
I hope that helps
nomanpatel
Jan 9, 2009
yes you can use quick pwn...its easy to use
